burgundyben
Re: Chris_d, me and the Nobel Prize
Quite right Antony.
The Greek bloke had it.
If you are more dense (physically) than water then you will sink and displace water equal to your volume minus the tiny bit of compression of your body caused by the pressure of the water (ah ha, another complicating factor!!).
If any item is less dense than water, ie less than 1 kg per litre volume, then it will float, the amount above the water is an expression of the ratio between density of water and the floating item.
Man in the bath is like boat that has been run aground, it is displacing some water, the difference between what its displacing whilst aground and not aground will be equal to the pressure it is exerting on what ever it has run aground on.
On the subject of my displacement, lets just say that its less than BIGMART and more than TCM. The amount is not important, these things are relative, I am relatively less heavy than my brother who is my relative, see?
<hr width=100% size=1>Sod the Healey - I think I'll buy an E-Type.
Quite right Antony.
