Airassmith
Active Member
Is battery negative and \'ground\' the same thing?
I'm installing a new chartplotter and GPS both of which have plus and minus 12V supply cables but in the case of the plotter (Raymarine E80) it says to connect the screen cable to ground and for the GPS (Furuno GP32) it says to connect the case stud to ground. I thought battery negative was always grounded? Can I just connect the ground cables to battery neg? Or should I run a wire to the keelbolt to which the mast to keelbolt lightning conductor cables are attached to act as a separate ground ?
