cmedsailor
There’s a couple sailing now to New Zealand (from Croatia) on their Elan Impression 384. Search “finding avalon”.
I don’t think you really understand this. With proper weather routing you can mitigate your chances of getting caught out but if you are really talking of going off piste you will waste days of time and neither you nor an Imoca 60 will outrun a weather system.
Sustained 40 knot winds in open ocean will lead to significant wave heights of 30ft. They will pick up your, or any other, sailing boat and twist it through surprising angles of yaw. If you want to avoid a crash gybe you will need an attentive helmsman who can “feel” what’s happening to the boat and take the appropriate action quickly and instinctively before it becomes a problem.
You will need to be able to do this at 4am in complete darkness when you are very tired.
If you are planning to do this two up the other person would need to be Ellen MacArthur but she will know how to pack well so I agree that would alleviate the storage issue.
Otherwise stick to the recognised routes and times...
________________________
We care about the planet. We never buy bottled water. We make our own water and store an emergency supply in jerry cans for ocean passages. We have had the same fuel and water cans for 14 years. We have 800 litres of water in our main tank. It is enough for two people for most ocean passages. We make water on-route when we need to. We never fill our tank from a dockside supply. In my experience contaminated water only comes from dockside suppliesI'd be hove to and go below for some rest until daylight. It worked for us.
The water tankage is a bit of a red herring as one or two big tanks can get contaminated so you need bottled all alternative supplies. Same with a water maker, you need bottles for the journey if that fails. Without water you are in serious trouble so that was one of our priorities. We carried enough water in bottles for the whole passage + allowance for a slow crossing where you may be under jury rig.
In open ocean you have the space to run with a storm or heave to, I've only done it in Biscay in November 50knts weather but it worked well and that was on a Bavaria 390.
Do you think you going to get 800 litres in an Elan 40?
___________________________
800 liters would be 1 meter x 1 meter x 80 centimeter (or any other combination) so yes, that would fit. And as there already is an approx. 250 liter tank on board you "only" need 2 more of those.
No weight is the issue not size.
Let's say we add 500 liters extra to the original 250L tank = 500 KG extra minus 4 people (6 berths of which 2 will be used) x 80 KG = 180 KG extra weight for water on 7200 KG displacement. I don't expect that to be an issue.
And then of course there is extra diesel, spare parts, food, etc.
A boat can only carry a certain weight before it starts to affect its designed stability and you’re not going to want that.
Just like an inflatable dingy it will be stated on the CE plate of the boat and you may be surprised how it varies from one “similar” boat to another.
If you are going long term cruising you’ll have a lot of stuff to start with.
In the OP you asked about handling in bad weather. It will handle worse with an extra half a tonne of water on board_
What basis do you have for this? Any objective reason?
I'd have thought a Jenny was as unlikely as Hanse - an issue at the top of my list would be:
Where are you going to put the stove (and chimney). Every yacht down there, boasts a chimney (apart from the cat that was in Punta Arenas - out of Tahiti) and the best selection of anchors and oodles (is that word acceptable) of shorelines.
Jonathan
