Zagato
I would be fine with 3 or 4 metres of chain. The only value of chain is avoiding chafe.
That would be superb, I could keep the 10m 8mm chain that came with the boat and 15m of rope and extend the rope somehow...
I might mothball the windlass and get 50 mts of 6mm chain to pull up by hand, an easy task for most.
Rope is well worth avoiding, on a small boat, esp with no forward open locker. What do you do? Lug the whole wet issue, anchor and all, back to the lazerette? Detach just the rope each time? Wet anchor rode is not the best companion aft of the foredeck.
Real World, Too
That said, given my general scepticism about anchor testing, I probably would not have written on this if it were not for the reports of sudden and inexplicable dragging of Rocna anchors that we have been receiving over the last few years.
Put the two together, and I’m convinced that there’s a real problem with the Rocna, and that concern extends to the Manson Supreme, since it is so close in design and Steve’s testing shows the same failure.
Failure Modality
The most worrying part of this is the failure modality that Steve’s video shows:
The Rocna fails to reset, not because a rock or large piece of debris has fouled the roll bar (as I always assumed), but simply because mud or sand has accumulated on the fluke—something that will happen in pretty much every set.
Or, to put it another way, these anchors set fine when clean, but poorly when even a relatively small amount of mud has stuck to them.
But Not Often
Having said that, I should point out that we have received only about 20 reports in what I’m sure are tens of thousands of successful sets, although, of course, many other failures may have gone unreported.
And, further, an aggressive 180-degree reset is a rare thing in real anchoring—90 degrees, yes (say in a cold front passage), but 180 degrees, not so much, except when anchored in a strong tidal current.
And that’s certainly a rational way to look at this, which I’m sure many people will adopt.
The OP only need a Gen Belgian 10kg Bruce, jobs a goodunWe had, on a previous boat, a 40lbs genuine Bruce. It was faultless for six years until one day in Osbourne Bay where we stopped for a lunch hook.
After three goes I retrieved it completely, not just clear of the seabed.
It had a round boulder completely blocking the point and flanks jammed between there and the shank!
So, it failed to set, but for a very good reason.
Nothing wrong with the anchor at all.................................
Here on the East Coast we have some similar anchorages to the one you describe. I solved the problems of a Delta not setting by changing to a Fortress. The Fortress easily penetrates the upper soft layer and bites into the firmer substrate. If it has been a good blow, it may take a little more effort to break the Fortress out - but I prefer that challenge to uncertain setting.Several years ago, when I used to frequent Chichester Harbour I often had problems getting my Delta anchor to set. Particularly in mud to the East of East Head, where a skin of soft lubricating mud covers a much denser substrate. So, I invested in a Rocnor anchor, expecting all my problems to be resolved. My first attempts at anchoring with the “new” anchor proved to be a failure as to my chagrin it persisted on skidding across the mud. That was my Damascus moment, when I realised that the blame for my anchoring problems lay at my door, not at that of the anchors. A thorough appraisal and ensuing revision of my technique has transformed my success at anchoring and proven to me that there is no “magic” anchor.
Mike.
The genuine Bruce has some unique properties, but it does not work well in small sizes. You will find the Rocna a revelation.It came with a 5KG Gen Belgium Bruce 10m of 8mm and 15m of rope. Not a bad shout for what he wanted. I am going to use it as a kedge, the Bruce has been my best anchor so far. I am going to sell my new 10KG Danforth, 7 KG Danforth, new CQR, old CQR, and Fortress, and large Grapple hook and Fishermans, all new or used a handle full of times to help fund my Rocna and chain/warp which looks to be £500-£600 ouch! May just get the Rocna this year and use the rode I already have... I have timing gears, engine bay spray etc to but for my old SAAB 96 and a blimmen shower and toilet to sort for the wife Lol!
Honestly you really don't need to spend that kind of money, although it sounds like you have worked through a variety of shapes already.
You stated off asking about deltas? I would revert to that if you can, I had a 10kg on a 26footer always set well and is a good anchor for the places you are going to go. I would suggest that using a anchor without any chain is a bit of a folly as the chain helps considerably with setting. Use what you have and don't over think it all.. Otherwise you end up convincing yourself to spend too much cash on another shiny trinket![]()
