Is a DC genset a good idea?
Sinbad1
14 Dec 2001
UK East Coast
Having had the AC genset seize can someone please tell me if a DC genset would be practical. I was thinking along the lines of a separate small quiet diesel engine with a large 150 amp DC alternator. The boat has 700 ah in AGM batteries. These batteries are stored forward, approx 5 meters from where the genset would be located. I could then run an inverter for all AC requirements on the boat. However does the inverter need to be close to the battery bank to avoid current/voltage loss or could I place the inverter anywhere?
Does this idea sound like it will work or do I just repair my big old noisy smokey genset?
pvb
UK East Coast
Could make sense...
If you don't have heavy AC loads (aircon, cooking, etc) then a DC generator could make sense. <A target="_blank" HREF=http://www.hflgen.com>HFL</A> make a 100A 12volt DC genset, using a little Kubota diesel. Suspect it's not particularly cheap.
As long as the cables are adequately sized to handle peak current without excessive voltage drop, you could put an inverter anywhere.
Stemar
12 Sep 2001
Re: Could make sense...
You can put the inverter anywhere, provided you size the cables appropriately, but economics dictate a position as close as practicable to your batteries.
Cable needs to be sized according to the current carried, not the wattage. 240 watts is only 1 amp at 240v, but you're looking at at 20 amps @ 12v, not allowing for conversion losses, so the 12v cable needs to be 20 times the size - and several times the price.
