john_morris_uk
Without criticising individual contributors there are a couple of basic misconceptions with some of the responses.
The first misconception appears to be when some people talk about 'boosting' the output of an alternator. A 60 amp alternator will NEVER produce more than 60 amps - it just can't because of the physics of the way that it is built. You can't even assume that it will generate anywhere near 60 amps for any serious length of time. With its normal alternator regulator, and assuming that the batteries will accept the charge, then it might get somewhere near to 60 amps for a few minutes, but then internal heating etc will derate itself and the output will fall. Manufacturers are a bit disingenuous when they 'rate' alternators and the quoted value will only be achieved under the most optimum conditions.
The boosting of the 'smart' alternator regulators will force the charging current to be at its maximum for longer, but we then come up against the physics of the batteries. The chemical reaction that occurs between the lead and acid etc can't be forced to occur faster than nature allows, and as the charge moves from the surface of the plates to deeper into the plates, the process slows down. No matter what you do, the batteries can't be forced to accept charge above a particular rate without excess gassing. The so called 'smart controllers' are much better than the standard alternator regulator at getting the batteries to accept charge, but they can't alter the physics of the batteries. Power in has to be more than power out in the charge discharge cycle and you can't achieve full charge in twenty minutes of motoring out of the anchorage no matter how big the alternator and how clever the charger controller.
This leads to the final bit of misunderstanding. Having a smaller alternator might not be optimum - but it will still work. I despair when I read people suggesting that a 65 amp alternator won't charge a large battery bank. Of course it will - but it won't be optimum and it will take longer.
To the OP: The alternator might not be ideal but it will be ok. A smart alternator charge controller (Sterling etc ) will help considerably.
The real solution is to measure daily power needs and budget to replace the power used accordingly. In other words how many amp hours is used by EVERYTHING on board - and then find a way of putting it back (plus a bit)
In the Med' some solar panels will make a lot of difference! Most long term sailors end up with a mixture of solar/wind and topping up with engine/generator as required.
FWIW we have a battery monitor that allows us to see how much power in and power out from the batteries at all times. Saves guessing!
