cherod
N/A
Well for one reason , a 240 v alternator is bigger than either of my engines !!?
I use the inverter at sea when the engine is running. It was cheaper than a 240v alternator and the fabrication needed to fit it.Why on earth would anyone want to do this via an inverter?
If in harbour on shore power you have access to unlimited ---shore power!
If your boat is so big and power hungry you feel the need for a microwave afloat wouldn't you have a generator anyway?
If not surely the most cost-effective way would be to add a cheap 240v alternator? That way you don't have to murder your necessarily huge (and hugely costly) battery bank.
MarkXal on Reddit said:Propane's energy density by mass is 46MJ/kg and by volume is 26MJ/L. An acid battery's energy density is 0.11 MJ/kg and by volume is 0.22MJ/L
So by mass efficiency propane is 418 times better, while by volume efficiency propane is 118 times better. Lithium batteries are about 10 times better, but propane is still 42 and 11 times better respectively.
link
Fine if you keep explosive pressurised gas on board. I don’t.
I eat a lot of ready meals, but I can't see how a microwave makes sense.
What microwaved dishes beat oven-baked lasagne or tinned chilli con carne?
Bloody hell! The levels of unnecessary grumpiness and wild accusations on this forum are quite extraordinary!I use the inverter at sea when the engine is running. It was cheaper than a 240v alternator and the fabrication needed to fit it.
As I said it works well which is why I chose to fit it that way.
Not really worth the emotive and dismissive language you used.
Don't understand that - unless your engine(s) are torqueedos...Well for one reason , a 240 v alternator is bigger than either of my engines !!?
Wait until about 3:00 in the morning. That's when it really kicks off.Bloody hell! The levels of unnecessary grumpiness and wild accusations on this forum are quite extraordinary!
Nothing on my boat is gimballed.
Richard
[QUOTE="KompetentKrew, post: 7276461, member: 170951"
Richard
Electric cooking is becoming more and more popular with liveaboard cruisers in hot places. Yes you need a big battery bank and a way of charging it up (solar is now incredibly cheap).
This is a big chunk of money, but it means you can do things like cook with an induction hob, which doesn't waste as much energy heating up the cabin, and it frees you from trying to find retirement gas bottles.
For your average weekend cruiser in the UK it isn't quite as compelling an argument of course.
I'm interested to hear it anybody on here has used their cheap PSW inverter with an induction hob?
I recently bought a Chinese made 1000W/2000W pure sign wave inverter on eBay for just over £80.00 delivered. It runs at 1000W continuous and a peak rating of 2000W necessary on start up of some equipment. It has been used and worked fine. For a microwave you do need a pure sign wave or it may not work correctly.
The Chinese company only make inverters and have a good range that are stocked in the UK or Germany, so this is why I chose this one. The model I bought is currently not available with a UK plug fitted. This is their current range. Items for sale by zyf-goodseller | eBay
