Puggy
I did just this on my boat. I connected my sterling 2500w inverter into the 13amp socket circuit on the boat, which allows me to run the microwave etc from the inverter. I did this by using one of these 16amp 230v non latching relays from RS http://uk.rs-online.com/web/p/non-latching-relays/2452396/. Wiring diagram attached (kindly supplied by another forum member when I enquired how to do this) My boat is older and doesn't have a newer domestic type RCD panel, the RCDs are separately wired and this is wired into the circuit between the incoming feed and RCD for the 13amp plug circuit. Default position, the relay connects the incoming mains 230v supply to the sockets, if your switch on the inverter, the relay senses this and switches over to disconnect the mains supply and connect the inverter. It works really well.
Best wishes
Puggy
Best wishes
Puggy
