Highland laddie
Hello everyone, I can apply ohms law to DC (just), however I am unsure as to the inverter wattage required to provide 230v @ 1.5 amps. Can the forum please help?
Hello everyone, I can apply ohms law to DC (just), however I am unsure as to the inverter wattage required to provide 230v @ 1.5 amps. Can the forum please help?![]()
it is also possible to run a specific 12v car charging unit to a laptop without going up to 240v and then down to (?) 19v DC).
Ebay and other sources.
http://www.google.co.uk/search?q=eb....,cf.osb&fp=511c47e743c6c5d&biw=1024&bih=1134
If you need a small inverter for other items, then 300 Watt is about OK
Many thanks for advice, I didn't realise that a 19.5v supply could be obtained from 12V, this is much simpler and cheaper than a 230v inverter. Is the 19.5v charger in effect an inverter, or is other technology involved?
Regards Gerry![]()
I've tested several 150/300w inverters, with laptops mains psus and the clever adapter below which is 12/240 in with multiple dedicated tips for laptops.
http://www.ebay.co.uk/itm/Belkin-Un...Accessories_PowerSupplies&hash=item33738d1d4b
(no connection)
My ammeter gives broadly the same current for either, 1.5/2A.
Have the people who dislike inverters tested them themselves?
Regards Gerry![]()
It's a DC-DC converter. What laptop do you have? I've got an extra one that fits various panansonic toughbooks.
The 12v converters typically use about 30% less power than using an inverter and 240v adapter. It does depend on the design and on the efficiency of the inverter.Have the people who dislike inverters tested them themselves?
Nick
No, I haven't but I don't understand your figures. A 2 amp drain on your battery at 12 volts is 24 watts. Most laptops use a lot more than that.....but not necessarily all the time.
What exactly were you measuring?
