ParaHandy
Last year I connected a set of 5 ST60 units (wind, depth, speed, graphic and multi) to an Autohelm 4000 through the raymarine bus. A 182 gps was connected to the ST60 multi and a JRC1500 radar connected to the nmea out of the ST60 multi. A pc based chart plotter is connected to the gps 182 as well.
All works fine except that:
a) the st60's from time to time bleep that they've lost the position input (from gps) for a few seconds but the gps does not show that it has lost satellite data and neither does the pc plotter and
b) very occasionally (but often at exactly the wrong time) the ST60 multi will not transmit heading information (from the autohelm) to the jrc radar. This is not coincident with problem a). When this happens, the jrc defaults to using the COG (which is also transmitted by the ST60 multi) info which could be disastrous if you weren't aware of what's happerning. The ST60 multi also displays the incorrect battery voltage and is going back anyway .. and the ST60 graphic nmea out never worked but wasn't needed ...
Problem a) is not that serious unless it starts to get worse which it may well do. I'm tempted to think that the raymarine bus isn't up to the job or that the aerial is mounted too close to the outboard on the pushpit - seems to be less prone on one tack than the other but that might be bolx ...
Problem b) is much more serious. The multi display was chosen entirely because it took the autohelm heading data and transmitted the nmea HDG sentences to the radar which uses this info for the EBL.
Anyone come across any of this and know a cure?
