Babylon
My insurer is trying to avoid paying my claim by saying there has been 'want of due diligence' on my behalf. What exactly does this mean, and are they using it as a 'catch-all'? I had previously understood that assured/owner/skipper negligence was covered.
The circumstances were that, when I installed a new engine a year ago, I made the mistake of connecting the seacock and hull-anode bonding wire to the starter-motor positive, rather than the engine earth. The consequence of this silly mistake was that 16amps were sent to the seacocks whenever the engine-battery circuit was on, rapidly eating away the bronze. Immediately upon realising the problem (the engine start battery had been losing charge very fast), I first dried the boat out on the nearest wall to have a proper look. Several seacocks were on the point of catastrophic failure and all needed replacing, so I had her lifted out as soon as it was daylight. I was extremely lucky not to have the boat take on water at sea, or sink on her mooring unattended.
I am not a professional marine electrician or engineer. I'd just employed both these professions to check and renew the old wiring, and to do the main engine installation, alignment etc. All I did was the donkey-work, eg repainting the engine bay, installing sound insulation, repositioning the primary fuel filter, etc. The bonding of the seacocks (which I subsequently discovered is no longer received wisdom!) was one of my last jobs before relauch: I was tired, it was getting dark, and I attached the wire to a convenient fixing which I assumed to be the negative.
So, where does 'due diligence' come in?
