rwoofer
Just curious as to people views on what is betterment or not. My 20ft boat is getting repaired and that means the one piece foam backed hull liner on one side has to be replaced. The existing material is no longer available and the closest available material is quite close in colour, but very different in texture (leatherette vs dappled). Basically it will be obvious the boat has been repaired. The only solution is for both sides of the hull to have the foam backed vinyl replaced, so that the repair is not obvious.
By far the majority of the cost is in the labour rather than materials. I would argue that nothing is better ie. foam back vinyl is still foam backed vinyl, it is just that the boat has been made cosmetically consistent so that the repair is not obvious and the boat has neither increased in value or decreased in value.
What do others think?
