rustybarge
I echo Vyv Cox's advice; I think you are greatly exaggerating the issue of insulation. We've cruised in arctic waters, and have slept aboard throughout UK winters and are now planning a jaunt to cold regions in the south, and we've done little to modify the plastic boat we have.
- The cabin simply does not have surfaces which are directly touching the hull. There are cupboards or lockers, or floors with tanks or storage everywhere.
- The ceiling will be insulated anyway as it's normal practice to use a sandwich construction and it's usually 50mm thick and lined as well. This is done for stiffness rather than thermal reasons, but it works anyway.
- The windows are small in any ocean going boat, so again double glazing isn't usual. We put black-out material (cut from dark grey camping mat) into the recesses when we want more insulation or to cut out the (24 hour) daylight.
- Unless you've a humungus yacht the cabin volume is tiny compared to the living room in a house, so heaters are over powerful and one finds oneself flinging open hatches even when outside it's 10 degrees below!
I can only speak for plastic boats, not for steel.
As as a steel boat liveaboard, I second what you've said.
the vertical surfaces can be insulated with any old stuff.....it doesn't matter!
the ceilings are a different matter as even the tiniest drip of water is ALWAYS directly over head!
Spray foam is the only solution, how do I know?
i didn't do it!
you will also need to spray foam underneath the walkways if you have living space underneath like bunks etc.
