Insulating the calorifier
alt
24 Oct 2006
Éire
One gripe I have with the boat is that the calorifier/hot water tank isin't insulated, bare steel.
Before replacing it, i'm thinking of trying to insulate it a bit in the hope it will help.
I don't want to use expanding foam as it's messy.
I'm at the advantage in so that it's square, so I could use sheet insulation and cut it to size.
Any recommendations? Would Kingspan do the job?
lambohill
13 Nov 2012
Ireland / Sant Carles de la Rapita
Very good insulating product, and it is what is factory applied to modern domestic calorifiers, however I would check with Kingspan about temperature safety / surface temperature of your unit, likely fine, but this stuff burns at a very scary rate!
alt
24 Oct 2006
Éire
Thanks for the tip, will check how hot the unit gets next time I get hot water
alt
24 Oct 2006
Éire
Are you sure it needs to be insulated? If its anything like mine there is an insulating layer already built into it with a metal outer casing.
This would make sense. In that case my calorifier is simply too small (I think it's only 15l) - I would love a 40l one, but that'd have to go into the 2015 projects
Trundlebug
4 Jan 2007
River Trent
You'll know if it's insulated from how fast the water goes cold.
With well insulated calorifiers on our boat, hot water lasts 36 hours before it goes below usable shaving / washing up temperature.
