instrument upgrade
HAWAIIAN
6 Jul 2003
Hawaii USA
My boat have Stowe Navigater and 250 Navsounder, the 250 Navsounder some of the function doesn't work (shollow and anchor watch) I planed to upgrade the log and deep instrument and install new wind instrument at the same time. I don't like open another hole in the bulkhead I would like Nasa multi display or Horizon. My question is the new transduers fit the old housing or can I use the Stowe transders and use the Nasa Multi display to make the job simple? Thank you.
<hr width=100% size=1><P ID="edit"><FONT SIZE=-1>Edited by HAWAIIAN on 06/09/2003 08:55 (server time).</FONT></P>
howardclark
16 Sep 2001
S. Wales
No real chance with the Stowe Navigator - that older paddlewheeel wont work with most systems now - I know i'm changing from a Stowe system too -you are better to move to a system that uses standard paddlewheels ( such as Airmar).
The sounder is a possibility. Firstly you need to verify the frequency it operates at probably either 50hz or 200hz, and then find a compatible system. Secondly check how the sounder wire is terminated - its a lot easier if the fitting is the same -if not you need to change the end plug which if you do it wrong will give interference to other instruments.
Good luck
Talbot
23 Aug 2003
Brighton, UK
Re: Gearbox
Could you please verify if you do recon/ or new TMP Gearbox
MK11 Type 12000
Sorry dont quite follow your question and its relevance to a recommendation for the Silva dataset of instruments.
