Sammy Lou
Hi,
I'm hoping for some advise for the most cost effective solution for renewing the instruments on a small (26') dual helm yacht.
Some background:
The boat is currently fitted with (1) separate NASA clipper depth and log units at the helm (tiller steered boat - instruments are mounted port side of companionway) and (2) separate NASA clipper depth and log repeaters at the pilot house helm.
The current (original) instruments are old but the depth system works OK. However the log does not & I assume that this is due to the (through hull) wheel/speed unit. I have no problem retained the old instruments if useful.
I have a new/second hand 5" GPS unit to fit at the helm this winter and would use PC or tablet or iphone etc for any inner helm nav.
I'm planning to buy and fit a mast top (mast is off the boat for winter at present) wind direction and speed instrument
The problem(s) that I have is that with the plotter and a new wind instrument installed where the current helm instruments are there is not enough room to (neatly) install two separate instruments for log/speed and depth and the for all new instruments is above my budget.
What I would like thoughts/experience on is (1) I can't work out what is the best option (cost primarily) for combined instruments and the dual helm repeaters. (2) What is the most suitable spec (a) wind, gps, depth & speed or (b) wind, gps and depth (with speed from gps only).
What have others done? I'd appreciate any wisdom/experience to help me make the best/most cost effective choice.
Thanks & Regards.
Some background:
Thanks & Regards.
