G12
The AIS antenna doesn't need to be mounted high up.
Well if you want it to have a good range it *does* need to be high up. AIS B only transmits on about 2.5 watts and as it's on a VHF frequency the range is very much affected by antenna height. If you want people (large ships) to see you further away then you want to get the antenna up the mast really.
I know loads of people seem to have them on the pushpit but to me that is a poor solution.
By the way, those Metz antennas mentioned above are fantastic. Use the very best coaxial cable and connectors you can, not the crap sold in chandleries. RG8X is cheap and smallish diameter but there are other great options if you don't mind spending a few quid extra.
I'm assuming you can't run a fat coax so this stuff is good for its 7mm diameter: http://www.nevadaradio.co.uk/cables-leads-plugs/antenna-cable/ssb-electronic-aircell-7---drum
