chubby
These look to be a sealed LED unit and supplied with two self tapping screws but no instructions! Tried to screw in the screws but the hole in the plastic is blank not pre drilled, so do you just push hard so the screw bites or pre drill a pilot hole? Tried that and it doesn`t work, so have I knackered the wiring inside with the drill, also breached the sealed unit and got bits of swarf inside? They look a good idea but some instructions might help!
