Boo2
Yes, that is correct and how both the tanks I have installed are arranged - and it works. However, some have a dip pipe for extraction so that may not be possible.
Is one of those boats your Bav 37, Tranona ? I'm thinking of installing a gravity drained waste tank under the side deck outboard of the heads in Sunrunner. The picture shows the location, I reckon I can get a 600x400x250mm tank standing vertically in the cubbyhole with adequate clearance above. This would put the bottom of the tank about 6 inches above the unheeled waterline. For simplicity I thought I'd just connect the heads outlet to the tank inlet and the tank outlet to the existing outlet seacock.
The issue is that Sunrunner can fairly easily put the rail under because of her tumblehome and I wondered whether below the side decks and around 6 inches inboard of the topside will be enough to ensure it doesn't backflood ? With the existing heads there is a loop in the outflow pipe but of course there's a valve in the (Lavac) heads pump so backflow is a bit less likely anyway.
Any ideas whether this arrangement would work ? I know I could always shut the seacock but it would be rather horrible to forget and have the whole tank contents backflow and spill into the boat.
Boo2
