frilaens
I'm just about to replace various ball valves and have used Sikaflex to re-fix all the through hull fittings that I could easily remove. Some were, however, well and truly stuck so I decided to leave them alone. When I try to screw one of the new ball valves onto these the handle now operates in a different place than before and therefore cannot be screwed tight. My local chandlery recommended Loctite to fix these into place, but the disadvantage is that they will need heating for removal and I wonder if Loctite would be effective on larger diameter fittings. Anyone have any suggestions? Would PTFE tape or hemp be effective if the valves are not screwed in fully (do they need to be screwed on tight?) and the valves are in use often?
Andy
Andy
