dan9487
Evening all /forums/images/graemlins/confused.gif
I'm installing a fishfinder (Garmin 140) and I'm unsure of what to do with the cable, I'd like to do a permanent job of fitting it by running the cable through the transom, along under the floor and out through the dash. Only problem is that the cable is moulded to the transducer at one end and has a 20mm ish plug moulded on the other. The first thing that comes to mind is to cut the cable, feed it through a small gland and re-join it but I'd rather not do this as it will void my warranty and I havent even used it yet!
Has anyone else had this same problem or know of some cunning ways around it or is it going to be out with the soldering iron?
