Chris 249
Okay, I'm not that new to assy gybes; in fact I did my first ones on an offshore boat in the '80s. But here's the rub - I've always done them on fairly fast boats with long poles like radical offshore boats, skiffs or cats, where the sail schlepped easily around the forestay when doing an inside gybe. Now I'm looking at doing them on a J/36, which is essentially a J/35 with a fractional rig and more furniture.
I'm not going to fit a bowsprit/donk/dork/pole, but instead will use a conventional pole. Because I'm used to inside gybing I was just assuming after the tack line was taken up and the pole taken off, you'd flip the kite over inside the foretriangle and aft of the jib as you do with a jib, and as we do with the MPS/cruising chute.
So why does it turn out that people with conventional poles normally either do an outside gybe, or an "inside outside gybe" where the clew passes behind the spinnaker but forward of the forestay, which seems to be begging for a wineglass? We have a three-halyard system (three halyards sitting side by side, all of them below the forestay) so the halyards shouldn't be any more of a problem than if we were doing outside or "inside outside" gybes. I suppose catching the spinnaker on the spreaders is a risk, but we've never done that with the MPS and the only time we used our new racing chute we gybed aft of the forestay with no issues.
