Injectors
Tamar
9 Apr 2019
All over the shop
I've just removed the injectors from my Perkins gennie, they came out ok, but the copper sealing washers are stuck way down in the hole on the head. I have tried to get them out using various pointy things, but have been unsuccessful.
Any ideas please?
There is a special tool I can buy for £20 if all else fails.
I used a softwood pencil on my BMC Captain when I changed the injectors. Push in gently and the inner ring of the sealing washer catches on the tapered end. Good luck.
A piece of threaded rod or a long bolt usually works. One that is big enough diameter to want to tap the washer. Wind it into the washer a turn with some downward pressure, then pull.
Just a thought, the washers are copper, they look in good condition, could I anneal them in situ?
Not really practical because to anneal the copper you need to get it to red heat.
Even if you could, I wouldn't re-use an annealed copper joint washer in that situation because although annealing softens it doesn't restore its original thickness.
All done, I poked around with a small flat head screwdriver and out they popped.
Thanks for all the helpful suggestions.
I am amazed how thin they are. I would say they are 15mm
They don't look good for re-use!
Previously you said
Possibly. I've never done a diesel course or seen an injector, so have no idea what diameter thread they typically have (and 38mess didn't tell us!)... Any tool in a Boy Scout's pocket must be a good suggestion..
Excellent teaching on this forum?
Oh, I've learnt lots! Not sure enough to compensate for failing recollection of having been on a boat, though...
