Gordonmc
Symptoms were rough running on tick-over, smoke at all revs and a smell of diesel in the exhaust and the final indicator, the sump oil level way over the dipstick mark.
I tried the trick of running neat diesel additive through the system but although there was a slight improvement, thing were still not right. I pulled the injectors which are mechanical and then found problems getting them tested and serviced.
The local "fuel injection specialists" I contacted do not do diesels and one further afield who I was recommended to by my local garage man would only do electro-magnetic injectors.
Eventually I hit on a company near Cumbernauld. On the phone they sounded confident they could do the job, even though the injectors were of unknown make.
So I drove over and as well as having properly working injectors again, I learned all about them as the proprietor explained things as he worked.
First, a spray test which found No. 2 (of four) was only working on two of five holes.
A strip down of that injector revealed something hard was lodged in the spray tip. Some fine work with a probe dislodged whatever it was after twenty minutes or so and multiple washes and air-gun blasts had all five sprays working.
A test then revealed the injector tip was weeping due to internal damage to the cone allowing fuel past the needle. That was cured by using a fine grinding paste which allowed the needle to seat.
All this was done as I waited and I was in and out in under an hour.
The company, with whome I have no connection: McAlister Fuel Injectors, Napier Road, Wardpark Industrial Estate, G68 0EF.
Sorry for the length of this post, but the service of this company and the depth of knowlege of Steven McAlister is worthy of passing on.
