kgh
New Member
I have to replace two injector sleeves on my AD41's. I've been advised that this requires a special tool to carry this out. Can anyone confirm this is the case or not. Thanks
kgh
kgh
kgh
Well I'm in the trade, Permateek South Coast, and usually do all my own work but this does sound like I might bow out and get a VP chap to do it ths time, thanks for the advice.
Can I ask why you have to change them and what symptoms did you get that indicated they need changing?
Cheers
Im a vehicle technician, like yourself was unsure at first but have replaced two of these myself on my tamd41a's, they are really easy to do with the correct tools.
See if you can borrow them from local Volvo dealer as you will not replace them without. There is no reason to pressure test afterwards, just drain coolant first, after replacing crank engine over with all injectors out to blow out any coolant, apply oil into bores and repeat, then reassemble.
