paulwornell
Active Member
I recently had my injector pump serviced (along with the injector) and while the engine runs fine once started (after much cranking) I notice that there is over fuelling at near full throttle. So the question is, would servicing an injector pump change the timing and cause overfuelling. I understand that the timing is adjusted by means of shims inserted between the pump and the engine block and the thickness of the shims should add up to the figure stamped on the pump + the figure stamped on the block at time of manufacture. I simply put back the shims that were there previously.
Perchance such a pump service could alter the timing is there an easy way to adjust the timing (i.e. shim thicknesses). I have read the manual and it appears to require special equipment to get the camshaft in the correct allignment to then use a micrometer to measure clearances.
All advice and experiences welcomed.
