Amp1ng
Hi All,
I’ve noticed my depth sounder has developed a disinterest in updating its display since the beginning of this season. It started off updating readings a couple of times an hour (flashing in between) then reverted to displaying 0 for a couple of days but now it seems to have picked up a bit and updates what I consider to be a believable reading on average every few minutes.
I immediately considered replacing the transducer (it’s an old Stowe unit) but on initial investigation I couldn’t confirm whether it was through hull or not. There looks to be a skin fitting and the transducer has a lock nut threaded onto it which bears down on the inside of the hull/skin fitting. If I remember rightly on the underside of the hull there appears to be an almost flush fitting dome shaped cap , is this the transducer head with a flange that butts up to the outside of the hull retained by the lock nut on the inside? Or is this a closed skin fitting into which the transducer is bonded or immersed in an oil reservoir?
Before I go disturbing all this lot is it likely that this year’s antifoul layer (cruiser Uno) has caused the problem in the first place?
