Richard10002
Have just removed the diaghram shower pump from the aft heads because its' base is rusty and we get rusty water seeping onto the shower floor for a while after a shower is finished. not sure if it was the pump leaking, or just water getting around it, sitting in the rust, (making it rustier), and then making its way out as the boat moves about.
This has been going on for years I would guess and, having removed the pump, there is an apparently ingrained rust stain under and around where it was:
When I say ingrained, I suppose it hasnt become part of the gelcoat, but's stuck pretty firmly to it.
I've tried 2 goes with Oxalic Acid, (Gel Kleen), leaving it for a few minutes as per the instructions and the result is as above.
Can I leave oxalic Acid overnight, or could it do some harm, or has it done what it can?
Any other suggestions?
