sailorman
Do you use both Sall the time or just to aid mnuveringi can see that 1at a timein non planing situation might work engine
Thankyou iam used to 1 engine plus sails y nxt bot will hve to a moboboI generally use 2 engines only when manoeuvring or in very heavy traffic or in very rough weather. My auto pilot has no issue with this. The economy is remarkable. @2200 rpm my boat achieves circa 7knts. With both running @2200 it struggles to make 8knts. Maintenance costs per engine are also reduced by close to 50%.
Whatever about extra drag, in my case at least, the numbers do the talking - 1 x 2200 = 7knts compared to 2 x 2200 = 8knts.Food for thought.
When running a single engine the stern gear will be creating extra drag underway.
On inland waterways the dead engine will need to started and shut down at every lock or when mooring especially in tight spaces.
Also you cannot alternate the engines if important stuff is run off a specific engine.
ie. calorifier/power steering or battery charging.
Save a few groats on fuel by wearing out some expensive bits of boat.?
I think it depends on what sort of boat it is, where you are travelling, and what speeds you are doing.I use both. The power steering is off the starboard engine only so that engine would be used most of the time.
When cruising…..it depends if you’re a displacement or planning boat.
I‘ve always found that most twin engined ‘planning’ boats don’t ‘plane’ on one engine.
Sometimes I’ve had to finish my ‘planning’ trip on one engine at ‘displacement’ speed!![]()
You are asking about manoeuvring at slow speed I presume? Use two engines in sync and the wheel or pilot to steer once in clear water.Do you use both Sall the time or just to aid mnuveringi can see that 1at a timein non planing situation might work engine
