Info for Perkins T6.354
JOHNPEET
24 Sep 2002
Anglesey
Hi all,
Just wondering if a anyone can help me out with some info that I need for the above engine.
I'm putting in new exhaust systems in my steel boat and the supplier of the water lift muffler requires the following so that he can size the pipe work etc and ensure I don't exceed the max exhaust back pressure.
I need the following:
Exhaust gas temp
Exhaust gas flow rate
Raw water flow rate
Max exhaust back pressure - this is the only one I can find in the original manual and is quoted as being 13"WG
Any advice would be welcome
John
coopec
N/A
23 Nov 2013
Hi all,
Exhaust gas temp
Raw water flow rate
John
I'm not a diesel mechanic but surely the Raw Water flow rate and the Exhaust Gas flow rate would be a function of RPM?
Maybe you could calculate it?
Engine Exhaust Flow Rate Calculation - Scribd
www.scribd.com/doc/133136109/Engine-Exhaust-Flow-Rate-Calculation‎
Mar 30, 2013 - Engine Exhaust Flow Rate Calculation - Download as Text file (.txt), PDF File (.pdf) or read online. ... America Navistar Nissan Perkins Renault Same
http://www.scribd.com/doc/133136109/Engine-Exhaust-Flow-Rate-Calculation
Regarding exhaust temperature surely that would be vary according to the load on the motor eg high RPM
PDF]
Engine Horsepower & Exhaust Flow Guide - Asia Donaldson
www.asia.donaldson.com/en/exhaust/support/datalibrary/1053747.pdf‎
perature and intake airflow rate must be determined to calculate the exhaust ... Engine. Maximum. Engine Type. Temperature. Backpressure. Diesel 2-Cycle .
How to calculate exhaust temperature of diesel engine - WikiAnswers
wiki.answers.com › ... › Mufflers and Tailpipes‎
Can you get carbon monoxide poisoning from a diesel exhaust leak from the engine? Yes, you get ... What causes high exhaust temperature in marine engine?
http://wiki.answers.com/Q/How_to_calculate_exhaust_temperature_of_diesel_engine
