Infiltrating liquid silicone in plywood
Chanquete
18 Jan 2013
Buenos Aires, Argentina
Hello Sailors
What is your opinion about the following situation?
After each heavy rain I have a small leak near the entrance hatch.
A small amount of water (three tablespoons) accumulates forming a tiny patch on a nearby small platform which is slowly infiltrating in the adjacent plywood walls.
I am stil investigating the origin of the leak.
Actually I was thinking in generating a small liquid patch of silicone and hoping it will infiltrate and seal the nearby plywood walls.
Any idea of how to dilute the liquis silicone in order to reduce its viscosity and facilitate the infiltration?
Thanks in advance
Chanquete
Chanquete
18 Jan 2013
Where boats are concerned silicone is an invention of the devil.
Use 'Git Rot' if you got rot in your ply. If your ply is sound but maybe delaminating a little painting, paint on a little warmed epoxy. Thin superglue works as well providing things are dry.
Fix the leak!
Since I didnt find the rain water entrance place my intention was to seal the plywood in order to stop water absorption.
Sometime the water patch remaind some days before I return to the boat.
Tranona
10 Nov 2007
Water enters ply through the end grain. Once it is in there is potential for rot. There is little you can do unless you have access to the end grain and then you may be able to dry it out and seal it with epoxy. If the water is on the surface of the ply it will eventually damage the coating and probably the top veneer, particularly if it is a modern thin veneer.. You can reduce this by cleaning off the coating and refinishing.
However, the only real solution is to find the source of the leak and stop it.
oldsaltoz
4 Jul 2001
Australia, East coast.
Hi Chanquete,
Avoid using Silicon on board. Silicon will stick to most things, however nothing will stick to silicon. If you somehow get a bit on any paintwork you will have a major problem when trying to re coat it.
Most skipper, me included have a total ban on the stuff.
Epoxy is good with plywood, stops water, Araldite is an epoxy based glue that can painted over if need be.
Good luck and fair winds. :)
steveallan
23 Aug 2001
Ayamonte
Thanks in advance
Chanquete
Mix with white spirit about 4:1 spirit/silicon
Maybe best to test on a scrap piece of ply first.
Soaking with canvas waterproofing may work
