geegrrl
Is this the regulator?
Does the aluminium box with yellow tape in the attached picture look like the regulator? An emergency charge would be very handy right now.
The regulator is mounted separately from the alternator, follow the wires back. Usually put in a cpbd out of the heat of the engine room either an aliminium box often with yellow tape to keep the lid on, or a squarish block of aluminium and potted electrics with a black plastic front. if the yelow tape type, remove the lid then hold the relay arm in to the contact, ie not the contact welded to the case.that will give full output. (so long as wires windings & diodes are ok)
