In the garden
Rum_Pirate
23 Aug 2004
A tiny Island, Caribbean
Existing gate opening 10’11”
Yacht & trailer width 8’4”
A bit tight- so solution
Make it 4’0” wider
The vehicle (not mine) has a 7.4 liter engine.
Now to find funds to rebuild 16” x16” column
And a new (sliding) gate
Are you sure the pool is big enough for the boat ?
Early afternoon sun. It is currently 84ºF / 29ºC. Too hot.*
Have arranged with my handyman helper/gardener to empty, clean items and scrub (disinfectant) out the lockers tomorrow morning early.
* Not even 98º in the shade. :oops:
[1st Verse]
Said it was 96 degrees in the shade
Please show us some pics of her "unfolded" when you can, that's clever boat origami folded up...:)
Will attempt to unfold the ama hulls tomorrow morning.
I will then take that opportunity measure the height from ground to u/side of bed to get/build stands to support the boat, although this is not a priority at this time.
We used standard builders metal trestles in option 1 above. Lower to jockey wheel to minimum, fit the rear set, packing if necessary to get a tight fit. Then wind the jockey wheel all the way up, fit the front ones, jockey wheel to middle, pull out the trailer. I must warn you that doing this gave me carpal tunnel and tennis elbow at the same time. Look after yourself.
