In praise of ... what is your belated good find?
gregcope
21 Aug 2004
So. Two recent discoveries that I think are great are; Wago 221 connectors and Hyflex Gloves! I knew of both. But had never tried them.
So I recently brought some Wago 221 Terminal Block Connectors. The newer versions can do upto 6mm2 cables. Quick, simple and strong. Coupled with some WISKA Shellbox Mini Gel Insulated Boxes - MJB2 - which are IPX8 rated! I knew of these before but was not a fan until I had to join between two to four wires in a hard to get to place. Pop them in the gell box. Some insulation tape. Done. I shall be getting more. I often used to solder with generous heatshrink (please no solder vs chrimp arguments) for strain relief. However these were in hard to get places and soldering was bordering on dangerous and it was hard to get the iron, wires and solder into the right places.
Second thing are Ansell Hyflex 11-518 Gloves. Never been a fan of gloves due to a loss of dexterity, but these are very fine, meaning I can still handle nuts/washers with ease. Combined with their cut resistance have saved my hands from lots of self inflicted abuse. Also good for winter jobs where you need to keep your hands warm. Available on ebay for a few £ per pair.
What things would you praise that you belatedly discovered?
I am a fan of Wago but I wanted something that resembled a choc block so could make in line connections. I found these Wago look-a-likes on ebay that come in 2-2 or 3-3 connections
5Pcs Compact Wire Wiring Connector Conductor Terminal Block SPL-2 SPL-3_vi | eBay
TudorSailor
Are those through connectors like choc blocs?
Looking for something like that for NMEA1803 cables (ie thin ones).
No .... these have a lift tab ... paired. I can buy with entry each end opposite or as I have entry same side next to each other.
Basically with finger nail - lift tab - slide in wire - close tab. Do same with tab next to it or opposite side to connect other wire.
You can also buy in single tab - just put both wires that need to connect under same tab.
Saves having to find small gauge screwdriver.
221s are a little smaller/squarer than the 222. The newer -6xx version can take 6mm2 wire if that helps, compared to the older -4xx that can only do 4mm2. Used them for things like solar connections.
My Grandma's recipes for stews, soups and casseroles srored in Kilner Jars that last for months if not more, and are indistinguishable from those cooked recently.
It only takes an investment in (admitteldy costly) Kilner jars and a big cooking spree at home , but your cruise can the benefit from your own real home cooked grub that merely needs warming up.
I suspect the same could be done with Lock'n Lock boxes.
Bye bye Fray Bentos!
