boatmike
Re: In boom reefing as opposed to the others
I think if you read my other post I did say that vertical battens restore the roach of the sail and therefore there is little loss of sail area. My own sail has vertical battens and is ALMOST as big an area as the sail would be if it were a normal sail.
It still has less roach than a sail with horizontal battens though, especially full length vertical battens that allow extremely high roach. You are also correct about loose footing but to be fair this can be achieved equally well with any sail. As this is supposed to be a debate between slab reefing and in-mast reefing I would suggest that the slab system still allows a bigger sail to be used and can also be flown loose footed so you cant really claim in-mast is better in that respect can you?
There is no such thing as a better mousetrap.......
A mouse can only die once........
