SteveE
Nice looking boat... but the stern thruster looks like an eletric whisk... I would say from the look of the stern it needs to be larger than that.....
Pardon ? Oops forgot what the original thread was about for a few seconds there. Thanks for the comments. I just remembered I had a couple of pictures of the thruster before the boat was launched. I am beginning to think my learned friend at the marina was in fact talking a load of tosh but maybe this picture will throw some light on the question.
PS First time posting pictures so it may not work.
I'm no fan of stern thrusters (though my new boat has one; they kinda insisted...!) but I agree with Deleted User that the one in that pics looks the right size to me. Not that looking at it really counts; what matters is the hp of the motor and the pitch of the prop.
Unless it is ventilating (ie mounted too near the surface) putting ears on it will not change the thrust, despite many advisers telling you it will. The thrust is newtonian and occurs at the propeller faces and nowhere else. You can alter the directon of the thrust with ears, but I can't see the point of that. My new sternthruster has ears but that is to stop the wash from it slopping up thru the swim platform, not to increase its thrust
jfm, did you find a solution to the safety aspect of sternthrusters with swimmers about? I remember you posting on the subject a while back. I was in the water scraping cling-ons off my props this summer when a numpty teenager on the flybridge decided it would be a good idea to put his feet up on the helm and accidentally pushed the sternthruster joystick. It scared the bejasus out of me
Yikes! No I haven't dealt with it yet, but will do when I take delivery. Mine are hydrualic so at anchor they will only work if a genset is running, which of course one will be a fair bit. Although the motors are hydraulic, the valve controls are electric so I am hoping there are enough isolator switches but if not I will just add a key switch
On yours you must have a 250Amp breaker for the s/thruster, operated remote control-ly by a solenoid on the breaker, right? In which case you can just use the remote control circuit to isolate the power to the st thruster, and use a key switch or hidden switch so no-one can turn it on except you
I know most aren't but my thrusters are interlocked through the engine isolator.
I often go down underneath but wouldn't dream of it with the engine/thruster isolator on.
Hurricane, does that mean that the thrusters are de-energised when the engine battery isolator switch is turned off?
I was thinking more of some kind of safety grille over the thruster tunnel ends but I dont know how much this would effect the thruster performance. Does anyone know of a person getting tangled up in a thruster mechanism and what sort of damage that person suffered? I'm also wondering what force it would take to break the shear pin on the drive shaft and whether that in itself is a safety mechanism?
All this thrutching about sounds far to complicated and difficult for me. I'll stick with the two hands on the big levers approch.
The only sensible conclusion to this debate is to eliminate both of the really expensive oily bits and just have thrusters. Then you could wiggle your way forward and backward at a much lower cost, of course assuming we had hlb's maneuvering skills, and also move sideways when needed. All these newfangled propulsion devices...takes all the fun out of docking safely!
