SimonNZ
Active Member
Hi all
Our Beneteau Oceanis 400 has some old RF wiring that I'd like to check is as good as it can be. This is the current setup.
The powered duplexer is old and rusty, I have no idea if it's actually doing anything or has just failed-over to passthrough.
The FM receiver works fine, as does AIS TX/RX.
1) I see 20 or so vessels when in the marina if it's busy and have seen other boats as expected when at sea
2) I can see my own boat picked up by other land-based receivers via MarineTraffic. The AIS splitter has a relay that switches in and out for AIS transmission - this can be heard when the AIST 120 is making a transmission.
VHF seems to work OK. For the one conversation I've had out at sea (haven't had the boat long) things seemed fine though I'm surprised to hear nothing audible ever in the marina really, even the weather channel sounds quite poor.
Is there a better way of arranging the setup?
Everything is linked to a single masthead antenna. The solar bridge is probably 8ft from the water - I could fit an AIS antenna there, or on a spreader a few feet below the VHF antenna to do away with the AIS splitter and introduce antenna redundancy. We're only coastal sailing in the daytime, so we'd only need to think about perfect comms in heavy seas if we failed to check the weather and/or got really unlucky. The AIS side of things is as much of a hobby for me as anything else.
cheers!
cheers!
