Lucky Duck
I notice many sets include both metric and imperial sizes, on a modern(ish) boat are the imperial ones ever going to be used?
Yes - but they are Whitworth - none of the 'imperial/metric' sizes fit exactly, so you need 5/16" Whit. Just done my friends seacocks but had forgotten to bring my original Britool spanners so had to use a small adjustable........ it was a very restricted space, left handed by feel only - it was not easy!The bolts on Blakes seacocks on my boat are imperial sizes.
Engine is a Yanmar 3YM20 (I also have a little used Tohatsu) so Metric should be fine?
1/2" and 13mm interchangeable, especially on older rusted nuts.
Others too are either good fits or a reasonable 'hold still' on a bolt while the correct spanner pinches the nut.
In decades spannering stuff, I've never found a use for a 3/8" spanner EVER. (but an open end one can be ground to make an emergency 10mm!)
I had to buy a set of small imperial sockets as I didn't have one small enought for the Racor filter bowl housing.
Do you mean 3/8 AF or 3/8 Whitworth-entirely different sizes.
The AF is smaller than a 10mm and the Whitworth about 16mm across the flats!
Ground out to 10 mm? Guess! (I have had a bronze, anti spark, oil refinery WW ring spanner, c. 1.25" across flats, for 40yrs, one day I'll find a use for it...) (And don't get me started on bicycle nut sizes!)
nothing to beat a good selection of adjustable spanners like those below but note that some are left handed, some are metric and a least two are Imperial AF. The one extreme right is of course Whitworth
