Sailfree
Changed it last weekend - what a struggle.
Firstly the pumps difficult position. I also bought the speedseal kit and thought it useful that they also supplied a plastic lever to extract the impellor. Plastic lever moved it a couple of mm then it would not budge. Against my better judgement reluctantly heated a small screwdriver and bent the end to create a lever. Levered against the pump body side. Did impact the side a bit but rubbed it down with W & D paper. Anywhere in UK to buy a extractor tool. I have searched and note that the Yanmar impellor can be threaded on one end for using a special extractor but sod law I would have inserted the new impellor the other way not knowing about this tool!! And other conventional bearing type extractors that work?
Last point could not seal the speed seal cover!! The cover is a circular brass while the original is shaped allowing it to miss a hose and circlip. Ended up cutting (sawing & filing) speedseal cover on one side to the original Yanmar cover shape to miss the hose!
Why is nothing simple.
