D
Deleted member 36384
Hi Folks,
My battery bank sits in the engine bay in what used to be the base for a generator, so quite convenient and relatively short cable runs from the alternators. I am planning on moving the batteries from the engine bay to the saloon, either under the chart table or, more likely, under the starboard saloon seat/berth. This will make the batteries more accessible by far as well as distribute quite a bit of weight to starboard; the yacht has a slight port list anyway (two heads and galley on the port side). The battery cables are about 15 mm diameter. The system is 24V dual alternators, split charging.
What are the issues that I may have to consider and plan for? I know that battery cable size may have to be increased but what else?
Thanks,
BlowingOldBoots
Thanks,
BlowingOldBoots
