MJ24
Last year I replaced my calorifier.
Now when I switch on the immersion, the pontoon fuse trips.
I have had a close look at the wiring, all seems to be ok.
How do I check the actual immersion heater??
I have put a volt meter across the positive and negative on the immersion, and there is a circuit.
With little electrical knowledge I tried the same with the ohms scale. It measured zero.
Presumably the problem is either with the switch, the wire or the immersion heater itself.
How do I eliminate the heater itself (as this is most difficult to replace?
TIA
Mj
TIA
Mj
