RAI
Well that may well be it I suppose. A pontoon earth voltage setting up a current through the copper outer of the heater element (and the SS calorifier) through the calorifier spiral into the engine cooling circuit and down the prop shaft to the zinc shaft anode. If I connect the pontoon earth line to the engine the current will have a shorter less resistant path to the shaft anode. Is this a good idea? Hmmm. Alternatives?The engine is likely to be true earth via propeller etc, mains earth can have a potential difference and yes, currents will flow from one to the other via cooling water. It does raise another issue regarding corrosion of the saildrive and propeller.
Oddly, there is no sign of corrosion on the copper element. There must be some sort of erosive tunnelling going on.
