Mort
Hi,
I have an issue where my Bukh DV20 has suddenly refused to start, no noises, nothing. For the past couple of weeks when I turned the battery power on I've been hearing a clicking sound for a minute or two but couldn't pinpoint where it was coming from. From inside I have checked the ignition switch and I don't have 12 Volts. If you look at the photo there is some sort of green relay that feeds the ignition switch, I do have 12 volts there but not on the wire to the ignition. I am wondering if this is the noise I have been hearing (that has now stopped) and this relay has failed. Can anyone identify what the relay thing is and whether I am on the right lines of why the engines not starting,
Here is a closer view
many thanks, Phil
many thanks, Phil
