lailow
New Member
I am working on a Ford 2728T. The boat has a starter switch and a key ignition. It does not start and the wiring is all there, but just not connected. I have found three loose wires (in the engine compartment) that come from the key in the dashboard panel. I believe one goes to the solenoid but I don't know where the other 2 need to be connected. I know the key switch has more than three wires and am assuming that the others are connected correctly. I have been told the key wires were botched on purpose to keep "live a boards" from being able to start the engine.
Can someone clarify where 3 wires from the key to the engine are supposed to be connected?
Thank you
Thank you
