Mudisox
I would buy anything from www.gunboat.com
+1
prefer the 48 by choice, then Ican sail her myself.
however I'll stay with my Commancjhe for now until the lottery coughs up my win.
Ahem! Have you met MoodyNick....? And I refer you to the notion that 'people look like the dogs they choose'...!![]()
I think MoodyNick needs to be pointed at the Wharram designs, seaworthy and spacious and with Nicks contacts he could probably build himself one free using materials reclaimed from rooting through the boatyard skips each evening.
Cheers, Brian.
You need one of these :
20% faster than an equivalent length cat.
2 metres headroom - not squashed into a central hull with no headroom
Apartment-sized living quarters on platform over three hulls.
Hulls only used for equipment and stores (or additional berths if required)
Conception by Eric Bruneel former technical director at Fountaine Pajot.
Architect : Michel Joubert.
Neel 45
But twin rudders are apparently devices of the devil![]()
But if they are connected to Anderson 22s they would be OK.
Depends on your intended use. If you just want a bit of fast coastal cruising on weekends and annual holidays then, yes, go for the tri. If you want to liveaboard and cross oceans then you want the twin hull..... I think I would bypass a twin hull and go for a trimaran, because
- Better sailing performance, esp. upwind
- more fun to sail
- more comfortable in heavier seas
- with folding hulls, fits into a marina berth at no extra cost
right or wrong?
(Purely hypothetical, just as a matter of interest)
So is a tennis court but you wouldn't want to live on one. I went to look at his first 50 footer as a liveaboard but even at that size it was like crawling into a drainpipe. The sub 30-footers have accommodation closely resembling a pair of coffins!
He isn't biting is he?![]()
Just for the record, I have no intended use or plans to actually buy more than a sensible monohull. It just struck me that trimarans are very rarely discussed in public.
At 12 seconds they are level, there are no waves, they are are going quite fast and then.....
- more fun to sail
right or wrong?
Wrong. The tri has all the disadvantages of both multi and mono. Accommodation is pokey , the boat still heels, safety is not as good as either cat or mono and the boat is only faster, comparing like with like, if you are into flying two hulls.
