UK-WOOZY
ITs that time of year now where i start work on my boat.
so i removed my perspex windows. one was cracked (which explains the bad leak i had). they are just bolted to the grp with bolts and caps which i cannot identify but would like to renew as well.
also removed the winches for servicing and am going to put a steel plate on the inside of the boat to spead the load and take away from the fiberglass.
So i am after some new acrylic/perspex, bolts and caps things, curtain track/pole clips. Also can someone recommend how i could fix the ladder too and the chips on my rudder..
thanks
window fixings
windows
curtain pole holder
ladder
(last year i used B&Q "stainless steel" sheets for mounting the ladder, this is the outcome)
despise B and Q products now.
winches which are being serviced
also have a leak through one of these bolts on the main track, but its nigh on impossible to get to them from underneath. wood supports are underneath covering them
thanks
window fixings
windows
curtain pole holder
ladder
