emsworthy
Hi hoping for some advice please.
The attached photograph is of a circa 20 year old ball valve which needs replacing as the valve shaft is badly worn from a loose fitting handle meaning the valve can't be easily shut without the use of mole grips.
As there is no sign of galvanic corrosion on this or the skin fitting (recent survey) I am keen to replace it with a ball valve of the same material. Can anyone assist in identifying what it is from the markings? The boat was fitted out in South Africa so the standard EU/UK marking may not be present.
Many thanks in advance of some sage like advice!
