CaptainBob
My hydraulic steering system (with two wheels) has one ram to the rudder. Four very long rods with threads on each end, and some nuts, hold the whole ram together.
The system has no visible header tank so I was keeping it filled to the brim to ensure it wasn't dropping too low. On reflection I think the slight level variation I was originally seeing was down to ambient temperature fluctuations and perhaps a bubble or two somewhere. So last summer when it got really hot, and I didn't open the lid for a few weeks as we were off the boat, the system over-pressured (I postulate) and caused it to start to drip a small amount of oil from one of the compression fittings and from the blank end of the ram.
Compression fitting now nipped up and seems fine, but the ram is a more difficult task.
It literally just oozes a little. Perhaps a drip a week. Easily manageable. But is it essential to fix prior to using the boat? Seems unlikely to suddenly fail catastrophically.
Is it a common problem? Easily fixed? Perhaps it just perhaps needs a new gasket after all.
I'm hesitant to strip it down as I understand (a chap in the yard once said) bleeding a hydraulic system is very difficult - and we have two separate high points, one at each wheel position, with no obvious bleed valve at one of them. And it's no big deal to just add a little oil as required - I check it regularly anyway.
TY
TY
