aquaplane
The boat is a Jeanneau Espace 1000 of 1982 vintage with a Vetus hydraulic wheel inside and a tiller in the cockpit. There are no numbers or marks on the steering pump that I can see. It doesn't look like the current Vetus or Wagner models.
I have had a new Autopilot fitted but have had a trial and the autopilot and inside steering positions both worked. It is suspicious that this problem has cropped up now but the autopilot work may not be the cause.
The wheel is now very light, previously I could feel some resistance, and the tiller doesn't move. I had a friend spin the wheel while I checked connections to see if the oil was pumping but leaking, no problems there. Only 10ml were needed to top up the reservoir so I wasn't surprised at that result.
I have taken the 3 hydraulic lines off the back of the pump and removed the 6 allen screws but I can't get the back off.
I'm wondering how hard I should try?
Is there any point? Can I do anything once I get the back off or is it a case of "no user serviceable parts inside".
Thanks in advance,
Bob.
Thanks in advance,
Bob.
