SV Kittiwake
Our new to us boat has hydraulic steering, with a check valve and bypass valve, and a Raymarine autopilot.
When I turn the wheel all the way to port, the rudder arm that the hydraulic ram is connected too moves to starboard and the ram is contracted nearly all the way into the cylinder, i.e. its shortest extension.
The wheel then can't turn the ram back to starboard, the ram gets stuck when the wheel is hard over. Turning the wheel back to starboard, the wheel just spins and nothing happens to the ram... But if I engage the bypass valve (i.e. disengage the wheel steering) for a second then switch back, then the ram will re-engage and we can carry on steering as normal.
It's not a massive issue most of the time, but it's worrying manoeuvring in the marina and realising the rudder isn't responding, and having to take a couple of seconds to re-engage it.
Can anyone give any clues what this might be? From the wheel turning but the ram not moving, could it be that the fluid is bypassing something?
Thanks for any help!
Ryan
Ryan
